Problem When Trying To Start!
Old Nov 14, 2008 | 03:59 AM
FRod's Avatar
Originally Posted by glc
How did this thread get onto plugs and injectors? Brew, are you sure you replied to the correct thread? Unless I'm missing something, all I see is a starter issue.
He is not in the wrong thread, he contributed a great diognosis that happends to be relevant to the situation, if you read a few posts back it says it causes crank issues. CRANK/STARTER
Old Nov 14, 2008 | 09:34 AM
wreedKR's Avatar
That is what I thought at first, Im sorry Jbrew! Guys in another forum told me this is my issue also. Jbrew/guys check out my thread and tell me what you think.
https://www.f150online.com/forums/en...-frequent.html
Old Nov 14, 2008 | 09:47 AM
jbrew's Avatar
The concerns I posted are real and can cause a crank no start. It's been a real problem so don't completely dismiss. That sucks that the OP never updated the thread. Symptoms the OP posted is what I was going on. I didn't realize the thread was 2 months old.
Old Nov 15, 2008 | 03:38 AM
code58's Avatar
Originally Posted by Rambler69
Have you seen the size of that starter? When mine did the same thing, I replaced it with an aftermarket and the truck has started great ever since. My motorcycle has a bigger starter!
They use a high torque geared starter motor. Virtually every manufacturer does now. Nothing wrong with that. The starters used to be almost all direct drive, so it needed a larger starter. That type of starter will generally last longer without problems (worn brushes or bushings) than the larger starters they used to use.
