Fuel pressure problem
Old Sep 8, 2008 | 02:31 PM
BingBong's Avatar
Have 97 F150 with famous V6. have replaced FPR twice as the fuel pressure is way over 70 lbs and ruptures the diaphram. Does the fuel pump also have a regulator in it ??Does the crank sensor have any influence on fuel pressure...Really stumped on this one
HELP
Snoop
Old Sep 8, 2008 | 03:36 PM
CRASH594's Avatar
Sounds like a bad fuel pump relay
Old Sep 9, 2008 | 10:14 AM
BingBong's Avatar
Have replaced the fuel pump relay twice.What can cause these to keep rupturing the diaphram???Really stumped HELP !
Old Sep 9, 2008 | 10:28 PM
bxstang2000's Avatar
Here is a very good article with alot of information. If you have a return system and have a regulator thats keep bursting the diaphram you likely have a clog in the return line causing your pressure to be so high. Here is a good article you might find interesting. Hope some of this helps... http://www.aa1car.com/library/returnless_efi.htm
