Sulfamic Acid
Old Sep 5, 2008 | 03:54 AM
Klitch's Avatar
Sulfamic Acid
Found some powder sulfamic acid, was wondering how brutal it is on copper/ alum and plastic. my probe has a lot of built up scale in the water jackets and i need to get rid of it.
i cant find much info on it other than its possible it may cause problems over time (unknown length of time)
we use this to treat our boiler-refrigeration at work, i talked to the boiler guy and he said it only takes 1 mil of scale build up to reduce cooling effeciency by up to 60%.
Old Sep 5, 2008 | 10:25 AM
Labnerd's Avatar
I wouldn't use it or expect a series of issues like aluminum radiator leaks and excess voltage in the system. It's hard on the copper parts and seals as well. I would suggest looking at this product:
http://www.qmimo.com/rmi-25.htm
This one is amino acid based and it offers several series of benefits that make it worth using as a permanent coolant additive. I'd suggest putting a bottle in the radiator system, driving it about 3000 miles, drain, flush and refill with coolant and another bottle so that the issue doesn't come back.
Old Sep 5, 2008 | 01:19 PM
Klitch's Avatar
so it is hard on rubber too? me and the boiler guy couldnt figure out if it was hard on anything else but copper... the reason i was looking at it was because i have an excessive amount of buildup. i should give you a picture, i need something that works relatively quickly.
what about coca cola?
Old Sep 5, 2008 | 05:53 PM
Faster150's Avatar
there was some Foam stuff that our neighbor gave us one time to clean our outside condenser for the house. it cleaned it up real nice!
Old Sep 6, 2008 | 01:43 PM
Klitch's Avatar
this is the amount of scale deposits im dealing with.
http://i252.photobucket.com/albums/h...e/100_0556.jpg
Old Sep 6, 2008 | 02:56 PM
McLovin's Avatar
Judging by the rust on those walls, you have bigger problems to worry about than the buildup.
What is your original problem? If you weren't having overheating issues before, i'd just let it be.
Old Sep 6, 2008 | 03:02 PM
Faster150's Avatar
get it heat tanked. or bead blasted
Old Sep 6, 2008 | 04:08 PM
Labnerd's Avatar
Maybe I'm not seeing everything in the pic but I don't see that you have that big of an issue. I've seen far worse and cooling wasn't an issue. If you have the block out and apart, get it tanked and your problems are over not to mention a nice clean block to work on and paint. I think your friends 1mm of scale= 60% loss is a little ambitious at best.
Old Sep 6, 2008 | 04:55 PM
Klitch's Avatar
blown head gasket + overheating after 1 week of installation of motor. im in the process of arguing with engine supplier.
1mm scale in an industrial setting, we work with large boiler and refrigeration systems at the plant.
the pics dont do much justice, there was plenty of scale down lower.
im just trying to salvage the motor for the time being until i can get money back for another via another supplier or something to that effect.
