lightning swap
Old Sep 5, 2008 | 10:25 AM
Stephen87's Avatar
Originally Posted by JMC
You will need the flywheel and clutch and possibly the slave from a SuperDuty. Let me know how that turns out. I am concerned about the BW T-Case bolting up to the ZF tranny. When you get that beast would you mind measuring the distance from the bellhousing to the centre of the shifter, in Neutral. Also the total length of the transmission.
Jean Marc Chartier
Will do.
Also how different is the wiring of a 2003 L engine to the wiring that is in my 97 4.6 will it work or will I need to get a slightly older engine.
Old Sep 5, 2008 | 10:48 AM
JMC's Avatar
JMC
25 Year Member
I should not matter which year of L engine you install. Adapting them to run in your 97 will present the same challenge. The basic engine controls of the L engines haven changed from year to year. The non supercharged engines have seen a few changes through out the model years. For example your 1997 engine uses a coolant temperature sensor. My 2000 4.6 did not.
The sensors that your PCM doesn't have are but the L engine uses are: Second IAT, BAP sensor, in tank fuel pressure sensor. There are also components that are controlled by the PCM that your 97 doesn't have. Bypass solenoid and the Charge air cooler pump.
Regards
Jean Marc Chartier
Old Sep 5, 2008 | 01:21 PM
Klitch's Avatar
i have a 97, i had to drill and tap 2 ECT sensors into the front main crossover in the L intake manifold. this is extremely thin metal so you have to be careful.
Old Sep 6, 2008 | 11:44 PM
Stephen87's Avatar
forgive me for the dumb question but what is an ECT sensor
Old Sep 6, 2008 | 11:53 PM
Klitch's Avatar
Engine Coolant Temp. speaks for itself.
Old Sep 7, 2008 | 01:20 AM
Stephen87's Avatar
sorry I had had a massive brain fart. I kept thinking coolant temp sensor but which one.
