A/C on all the time?!
Old Aug 13, 2008 | 10:02 PM
tfast150's Avatar
so cold and panel and floor is very cold!!...im pretty sure my A/C is running all the time...what do i do?! (2003 5.4)
Old Aug 13, 2008 | 10:11 PM
Matts ford's Avatar
sounds like the a/c switch to me. or compressor clutch problem.
Old Aug 13, 2008 | 10:15 PM
tfast150's Avatar
wheres the AC switch?
Old Aug 13, 2008 | 10:21 PM
Matts ford's Avatar
its right behind the panel to choose a/c or vent and defrost and all that good stuff. the **** slides right onto the switch. do you feel the air blowing through the vents at all times?
Old Aug 13, 2008 | 11:13 PM
RacingJake's Avatar
You could unplug the compressor clutch and see if it's still turning, if it does then you know its a clutch problem. Just make damn sure the engine is off before you do it and that the wire is clear of it too.
Old Aug 14, 2008 | 07:40 AM
projectSHO89's Avatar
READ YOUR OWNER'S MANUAL!
It tells you how the system is supposed to work. After reading your manual, determine if the system is working as designed. If not, then it is possible to help.
Old Aug 16, 2008 | 04:48 PM
tfast150's Avatar
i know its not working correctly!...its freezing cold!!! and doesnt really get any colder with the switch on A/C....
Old Aug 16, 2008 | 05:27 PM
Matts ford's Avatar
did you try any of the tips you were given?
Old Aug 17, 2008 | 07:41 AM
sigh.....
What else can we do?
Old Aug 17, 2008 | 02:23 PM
chiefFX4's Avatar
you do realize that the only setting that doesnt turn the ac on is panel. all other settings will actually turn the ac on.
Old Nov 15, 2008 | 01:44 PM
JHL's Avatar
JHL
Question Might be overlooking the *****...
I had a similar issue with my 1998... it was 2 cracked ***** spinning freely on shafts.
Pull your existing ***** straight off and check for cracks where the **** goes over the shaft... if its cracked you need new ones!
