changing the plugs
their not hard, their just a major PITA cuz they will just snap off, really bad deal
You really need to do a search on the subject and do a lot of reading. Also, do a search for the TSB that is Fords solution. Yes, the problem is real, especially if you do not follow the TSB.
I went ahead and searched for the TSB, see post #8.
https://www.f150online.com/forums/en...g-removal.html
You still need to do the Advanced search on "sparkplug change"
Read the past post on plugs first....
Depending on where you live...ie corrosive/wet environment doing it at half the interval may only give you half the problems or maybe you will be lucky. Overnight oil soak makes a huge difference.
Good luck!
Good luck!
https://www.f150online.com/forums/en...ug-change.html
https://www.f150online.com/forums/en...ese-plugs.html
