4.6L engine clatter almost sounds like diesel
I have 140k miles on my 2000 4.6L V8 and it has serious engine clatter at idle. Very annoying and it sounds like it's coming from the left side of the engine. Can't tell if it's lifter noise or maybe coming from the timing chain area. Sounds like it is in the front part of the engine.
Anyone know how to check this out myself without to much work. I thought it might be the belt tensioner pulley or the other belt pulley and replaced both of them but no change in the noise. I don't know where to start looking next.
If you have a digital storage oscilloscope, you could take a cam/crank waveform and see if it has any timing chain problems. Without that, you might be able to remove the valve covers or even just the cam sensor, and look into the timing cover with a boroscope (small camera) to see if you can identify the problem. Without either of those, you're down to pulling the valve covers off and having a look.
