just a quick question
Old Aug 9, 2008 | 05:37 PM
mark razmandi's Avatar
does a misfire happen from driving it too hard or is it random and can happen to anyone? or is a misfire enduced from anything else
Old Aug 9, 2008 | 07:19 PM
f150fella08's Avatar
miss fires done just randomly happen, ive had my truck for a little over a year now, had one miss fire only because the rubber seal (o-ring) was worn out and broke or whatever, and it rained and water got in there, hooked it up to a computer and figured out what cylinder it was, got online found out the order of the cylinders (lol) took that coil pack off and replaced that rubber thing, took a air compressor and blew out that water, and dried off the plug, put it back together, and everything was good
Old Aug 9, 2008 | 08:37 PM
Matts ford's Avatar
anything can cause a misfire. alot of people can have a misfire and not even realise it until they throw the pedal to the floor and it just shakes.
Old Aug 10, 2008 | 01:17 AM
yea my dad is going nuts on me saying that i did it because he "knows" i drive it like a ferrari....when i drive it very "grandma like" most of the time...haha....it threw a code when it happened but since then i reprogrammed my truck with my superchip and cleared the code like an idiot so now i dont know which cylinder it is.....is there a way i can find out or do i have to wait for it to throw another code
Old Aug 10, 2008 | 09:54 PM
Matts ford's Avatar
you can either wait or you can have the truck running and pull each of the coil plugs to see which one isnt making a difference.
Old Aug 11, 2008 | 02:05 AM
while it was ating up today i just decided to hell with it and i plugged in my programmer and it threw a code even though the light had not come on....its cylinder four....so i need ot just replace the plugs and the number 4 adn 7 coil?
Old Aug 11, 2008 | 02:51 AM
MmmBuckles's Avatar
mostly likely that will fix the problem
Old Aug 11, 2008 | 04:06 AM
cool...dude when are you gonna be at the next meet
Old Aug 11, 2008 | 05:03 AM
MmmBuckles's Avatar
ill be there this week hopefully. i dont think im going out of town, and as of right now i dont have work. i hope to have the interior on the truck finished by then.
Old Aug 11, 2008 | 01:04 PM
badass.............so should i replace my wires too...........and area ll spark plugs the same or are there better ones? i heard for my truck i need to use motorcraft ones....and same question for the wires...are they al lthe same or are there like "performance" ones
Old Aug 11, 2008 | 01:12 PM
shifty_85's Avatar
You dont have wires you have COP's *Coil over plug* insted of 2 coil packs you have 8 coils going right into the spark plugs. Use Motorcraft plugs other wise you will have alot more miss-fires in about 3,000 miles. As for the COP's on Ebay alot of guys on here use global COP's
Old Aug 11, 2008 | 03:13 PM
yea i found out i didnt have wires this morning lol and i already knew aobut the motorcraft.....thanks alot for your help and i heard its a PITA to do so should i get it done or jsut do it?
Old Aug 11, 2008 | 05:41 PM
Matts ford's Avatar
its not as bad as it seems. but it does definately take patience to do the plugs. the only pita is if and when you break a plug.
Old Aug 12, 2008 | 02:25 AM
man.....do yall think it could be a leak in my vacum hose perhaps?
Old Aug 12, 2008 | 02:35 AM
MmmBuckles's Avatar
thats also a possibility
