97 f150 4.6L please help!!!
Old Aug 27, 2008 | 11:24 PM
jbrew's Avatar
Originally Posted by josh_new05
ok so the truck had 16lbs of pressure at the fuel rail. replaced the pump. ran great for 3 days. started the process all over again. took bed off pump out hole was in the connecting line that connects pump to sending unit., put it all back together last night and its doing the same exact thing today. sounds like bubbles in the tank when the pump turns on. any ideas as to why this is happening?
Test the pressure once more - DON'T forget the regulator. Think you have a bad line that goes into the tank from the filter, they do spilt.
Old Aug 28, 2008 | 01:12 AM
Pheonixx's Avatar
i had an explorer do the same thing, it had a 4.0v6 slamming the gass bogged it to death. easing into it was smooth sailing. replaced the MAF with a new one...problem went bye bye. cleaning the MAF only gets ya so far. and those other codes could conceivably be caused by a bad MAF. dirty air comming, or misread clean air can cause all kinds of problems.
Old Aug 28, 2008 | 01:20 AM
jbrew's Avatar
Here - http://www.fordscorpio.co.uk/fuelmonitor.htm
Old Aug 28, 2008 | 11:02 AM
T Ellenberger's Avatar
You said you ran it out of gas. I did that to an old 82 Datusn and forever after that I had fuel filter problems. I think there was junk in the gas tank that broke loose after I ran it out of gas. The cure is to have the gas tank cleaned and sealed.
I hope this is not your problem.
I do not know how to verify the problem, just offering something to consider.
Old Aug 28, 2008 | 03:47 PM
FF301's Avatar
when my fuel pump went on my 87 f150 (I6) [great eng] the pump impeler broke apart and sent debret into the fuel system -yes i ran low on gas also-
clean system completly filter, injectors- all of it
