Common sources for wet plugs/cops
Old Aug 8, 2008 | 02:06 PM
Jesse H's Avatar
5.4 V8
Bought the truck 2 yrs ago and the COPS were bad after the dealer detailed the engine and got everything wet.
I replaced all plugs and COPS and truck was running great. Lately it's been missing only under load, overdrive, under 1500 RPM. Everywhere else it drives fine. No check engine light.
When I look under the hood the valve cover on the passenger side isn't wet, but it looks clean as if it's getting wet then dries off. I'm assuming I'm getting moisture from somewhere but I can't seem to locate it. AC lines don't seem to drip directly on the valve cover and COPS.
Old Aug 8, 2008 | 02:12 PM
joshmac4.6's Avatar
Heater hoses over the passenger side valve cover are prone to leaking.
Old Aug 8, 2008 | 06:57 PM
CRASH594's Avatar
Or the seal where the hood meets the fire wall Mine was leaking under the seal so I put black RTV under it. that solved my issue
