Battery Explosion?
I had some acid leak around the toyo battery. I think it was because it was hit int he ffront end pretty hard. I cleand it several times but the corrosion kept coming back around the terminals and I noticed a lot of corrosion under the battery on the metal. I bought some terminal cleaner and protectant and that seemed to help.
I'm no expert but maybe if you took it off road, if it was in an accident, or a big enough pot hole could have jarred something loose. ?? Maybe??
Just a thought
Just a thought
