P-1SC 1 Tranny 0
Old Jul 18, 2008 | 09:55 AM
Zaairman's Avatar
Originally Posted by jbrew
I have to say , I have never seen or heard of that being done - That would be cool.
http://www.talkdiesel.com/showthread.php?t=440
I've seen it in person... It's a nice ride. It's weird, cause you never expect to hear the woosh of air from the air suspension.
Old Jul 18, 2008 | 12:04 PM
JMC's Avatar
JMC
25 Year Member
FWIW I was running a Luk clutch kit. I would have never suspected the clutch would spin like that. I have had clutch slip under high stress with this one before and others for that matter. Because of the weak tranny I don't want a clutch that will hold. It tends to kill the trannys faster if they hold.
Regards
Jean Marc Chartier
Old Jul 18, 2008 | 07:17 PM
jbrew's Avatar
-Hey, what trans would you go with - by choice?
Old Jul 18, 2008 | 07:34 PM
JMC's Avatar
JMC
25 Year Member
A ZF 6 speed and a New Venture gear T-case from a Superduty.
Regards
Jean Marc Chartier
Old Jul 19, 2008 | 05:40 AM
jbrew's Avatar
Damn - Didn't feel like joining to those pics this morning. I almost did - No Time.
Been using a Ford 7.3 @ work to survey Corn Fields - Corns taller than I am here, Mann was that a blast yesterday until I nailed a washout and Eddie almost came thru the back window - Guess were getting a John Deer Gator w/ballooney tires to use today.
Never Corn Fed a Ford before - It seemed to like it.
Old Jul 19, 2008 | 05:48 AM
jbrew's Avatar
Regards
Jean Marc Chartier
Well, Christmas isn't that far away - would it bolt up
Old Jul 19, 2008 | 11:31 PM
JMC's Avatar
JMC
25 Year Member
Using a SuperDuty Flywheel/clutch kit and modifying the tranny mount will make it fit.
I will also have to use the SuperDuty Yoke at the T-case and fab a telescoping driveshaft. The SD doesn't use a slip yoke at the t-case. For now I put an Clutch kit from Xeddy. http://www.exedyusa.com/ It came with a new pilot bearing and the correct throwout bearing. I picked it up Friday afternoon and the truck is running as of 4:00 P.M. today. My wife wanted to go out last night.
Regards
Jean Marc Chartier
Old Jul 20, 2008 | 02:52 AM
jbrew's Avatar
Regards
Jean Marc Chartier
A telescoping one eeeh ..A dual set up ? It would have to be - Shaft 1 telescopingly receives a Shaft 2 - via Mid-shift ? And a few tubes of grease
She could of went out .. Shoulduh sent her out to the beer store to fetch at-least a 12 for a clutch job. That's sort of a compromise
Old Jul 20, 2008 | 03:14 PM
JMC's Avatar
JMC
25 Year Member
It would have to be the same kind of drive shaft as the front one, 2 piece telescoping. By the time the tranny was on I was wasted so going out seemed like a plan. Saturday I couldn't start till about noon.
Regards
Jean Marc Chartier
Old Jul 20, 2008 | 09:36 PM
jbrew's Avatar
I wonder what the difference in shaft length is , from stationary to boost. - Right before launch. Huh - Should look up that Fordgirl chick and have her measure that for me.
Just out of curiosity of course. ( :
