Bent Push Rod
Old Jul 9, 2008 | 10:56 PM
hajaygol's Avatar
Bent Push Rod
I have a 1988 F150 4X4 standard transmission. The truck runs but not well. Had a mechanic friend check the compression and found that #2 cylinder was dead (zero compression). I don't have a blown head gasket, and when he removed the valve cover, he found that 1 of the push rods was bent to an almost "Z figuration." Could I just replace the push rod and valve spring and turn the valve stem to see if the valve would seat and check that it is not bent? Would this be a safe thing to do to see if it would run without removing the head?
Old Jul 9, 2008 | 11:34 PM
Faster150's Avatar
id replace the engine..
