New Injectors and MAF
Old Jul 6, 2008 | 09:59 AM
bxstang2000's Avatar
My Stang is finally almost running, I upgraded to 60lb from 42lbs injectors and a PMAS HPX MAF (blow thru) from a 90mm Lightning MAF. I also added a BAP and a couple other items. My question is can I idle the car in the driveway just to make sure its running properly before I set the dyno appt. I don’t want to damage anything but i do want to make sure its running right before I make the trip to the tuner.
Old Jul 6, 2008 | 11:30 AM
ONELOWF's Avatar
I wonder. The maf is uncalibrated and the 60's will probably dump too much fuel for it run at all. If that is what happens, the plugs and cylinder walls will wash with fuel. Just my guess.
Old Jul 6, 2008 | 11:36 AM
phil6608's Avatar
Even if it starts,,it will not run properly .
Phil
