V8 Swap
Old Jun 28, 2008 | 09:51 AM
dirtrider596979's Avatar
V8 Swap
is it possible to put a 5.0 in a truck with the 4.2?
things im concerned with:
tranny/bell housing-i have a manual
motor mounts
space between trans and radiatior
drive shaft
ac
fuel pump
the doner vehilical is a mercury mountainer, i have the whole truck so electrical isnt going to be an issue
i was planing on putting on bbk headers with a costom system with highflow cats, magnaflow mufflers(gotta research them more) dumped.
Old Jun 28, 2008 | 12:20 PM
chiefFX4's Avatar
sure. anything is possible with enough time and money.
not worth it in this case.
Old Jun 28, 2008 | 12:32 PM
JMC's Avatar
JMC
25 Year Member
motor mounts
drive shaft
ac
fuel pump
The tranny bellhousing pattern is the same. The motor mounts may have to be tweeked to fit. Measure both engines and if need be use electric fans in front of the rad as pushers. The driveshaft should not be an issue as the tranny is not moving. The A/C piping will not line up but any competent shop can hook you up. (pun) The fuel pump will be fine. It supplies a 5.4 stock. If not a $115.00 Walbro 255 l/hr kit will fix that.
Regards
Jean Marc Chartier
Old Jun 28, 2008 | 06:07 PM
600Polaris's Avatar
nvm.
