Coilover Plugs, which one?
Old Jun 9, 2008 | 11:21 PM
GTRugby90's Avatar
I'm looking at replacing my spark plugs and coils. I'm thinking either MSD or Accell. Which one do you guys prefer or do you have another recommendation. Thanks
Old Jun 9, 2008 | 11:46 PM
tjk_in_cny's Avatar
Jbrew has offered this suggestion quite a few times. When I need them, I'll be buying them from ebay.
jbrew
Senior Member Join Date: Oct 2005
Vehicle: 1998 Ford F150 4x4 5.4L
Quote:
Originally Posted by Crownie
Fuel filter maybe?
Could be - But it's probably a coil, I would just replace them all . Low grade misfires aren't picked up by the monitor. Usually you need Primary or Secondary failure to generate a MIL.
Quite a few members , including myself has had good luck w/these. -
http://cgi.ebay.com/ebaymotors/NEW-I...mZ160246547539
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Polished TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Custom Intake w/WIX Filter, 265/17 GY Fortera's.
Old Jun 10, 2008 | 04:37 AM
phil6608's Avatar
If your not having a miss problem,,,,your better off keeping the stock ones!
Phil
Old Jun 10, 2008 | 10:58 AM
lowflyingbird's Avatar
COP's
Stay away from Accell like the PLAGUE!!! I dont care much for MSD either. It does seem like most of the performance aftermarkets are crud, and dont last long. I have bought several times off Ebay from a seller named "Global,..something?" They are like $100. for a set of eight, then get a set of the solid stainless 0ohm connectors and silicone boots.also $100. I only found them thru RPM Outlet. Some people claim issues with them, but I have made a few purchases from them with no problems.
Lowflyingbird
PS, for the love of god do not use Bosch platnum plugs!!!!!!! As a mechanic I have come across so many engine miss problems from them, where the electrode simply dissapeared. I use Motorcraft regular platnum plugs ,never a failed plug yet. I now have to back to Autolite resistors due to my Jacobs DIS ignition in my 97 4.6.
