E-fan question
Old Jun 2, 2008 | 05:30 PM
Jeff2005F150's Avatar
E-fan question
Hello
Would two 12" dual e-fans with s-blade design rated for 3600CFM total be enough cooling for a 2005 5.4 liter supercrew?
Jeff
Old Jun 2, 2008 | 06:18 PM
phil6608's Avatar
I don't think so!
Phil
Old Jun 2, 2008 | 06:30 PM
ScrewedUPF150's Avatar
Dont skimp on the fans I think you need at least dual 15 inch if I am not mistaken. Better to have more fan than you need than not enough.
Old Jun 2, 2008 | 07:25 PM
chiefFX4's Avatar
i think youre looking for at least 4-4.5k cfm. more is always better in this case.
Old Jun 2, 2008 | 07:27 PM
Faster150's Avatar
get dual 16" fans
Old Jun 2, 2008 | 09:31 PM
Galaxy's Avatar
With that set up it may very well take both fans all the time to maintain, leaving no room for super hot/heavy working days. Your truck doesn't exactly have the biggest radiator in the world so it needs all the help it can get. Most 16" S blade fans will pull almost that much with one.
Old Jun 3, 2008 | 11:42 AM
lenore's Avatar
or go with a junkyard lincoln or late model year thunderbird fan (18inch) that moves 4300 cfm. Then get this controller:
http://www.dccontrol.com/0820.htm
see my installation under efans in my photos...
Old Jun 3, 2008 | 04:33 PM
Thanks guys
I have an e-fan setup already but it is a junk yard fan and I think the bearings must be gone or something. Every time they start up you can feel them vibrate through out the truck. And with the the hot weather starting to come I don't went them to crap out on me.
I think I will get two 16" fans.
One other question what is too high of an amp draw? The fans I am looking at have an amp draw of 8.4.
Jeff
Old Jun 4, 2008 | 12:37 AM
Fifty150's Avatar
Originally Posted by Jeff2005F150
Thanks guys
Jeff
That is a problem when you buy auto parts at a junk yard. Remember that you are buying someone else's "junk". I'm not against "automobile recycling". It's a great way to save a few dollars and get what you need. You just have to keep in mind that you are not buying anything new with a warranty. I've always stayed away from certain things like used or re-capped tires, or anything else that you don't want to fail (like electrical parts). But it is a great way to get your hands on things like body panels, window cranks, dash buttons, signal lens caps, et cetera.
Thanks guys
Jeff
I have a kit sold by Mike Troyer. It drops right in and plugs right up. You won't have to worry about fabricating parts or brackets, or worry about the electrical draw.
Old Jun 4, 2008 | 02:12 AM
Klitch's Avatar
i run dual 16" fans, starting to think about making one dedicated to switch on/off only when key on.
Old Jun 4, 2008 | 09:19 AM
lenore's Avatar
another fan that works great is the Ford Taurus fan, it moves 3800cfm. As for current draw, it depends on the controller...The DCcontrols controller does a soft start, starting the fan at slow speed and bringing it up to speed.
Old Jun 4, 2008 | 11:37 AM
spike747's Avatar
Not exactly the biggest radiator in the world? This rad is 20 litres compared to GM and Nissan's 13 litres. It's huge! It was one of Fords big marketing points when this new truck style came out.
Old Jun 4, 2008 | 12:01 PM
wildbadbill's Avatar
do you have a contact address there?
Old Jun 4, 2008 | 12:06 PM
Galaxy's Avatar
Well if you think that radiator is big then you should see the one in my truck!! The physical size of the radiator is a moot point if it still barely does the job, and that's what the radiators in these trucks do...barely the job. Case in point, dual 16" electric fans. When I had my stock radiator I had my 16" S fans set to turn on at 205* and 212*. It was very common for both fans to run in the summer time either in traffic or when pulling a load or climing a hill at slower speeds. And he wants to run two little fans under those conditions. With my 2 core radiator, my second fan never turns on automatically under any conditions. Best way to really explain and see all this is intall a real water temp gauge.
Oh yea, I'm sure you've heard or know about this, but your factory temp gauge in the dash is a completely useless ornament. I have monitored mine with a real one and mine reaches the "normal" resting place right around 160*. I have seen my water temp at 230* and guess what that needle in the dash did...not a darn thing!! So unless you've got a real gauge you don't truely know what kind of job it's doing.
Old Jun 4, 2008 | 01:23 PM
Klitch's Avatar
wildbadbill - www.troyerperformance.com
galaxy, im not sure how you know your fans are running when your driving? i know my truck makes way too much noise to know the fans are running.
