Finally Its Gonna Happen
Old Nov 30, 2009 | 06:50 PM
  #1081
built54's Avatar
Yea Ill run a big power wiring coming out of the fuel pump fuse, which is how I did mine, so you still retain the factory fuel shut off switch and all that good stuff.
Old Nov 30, 2009 | 08:42 PM
  #1082
boss1984's Avatar
Awesome. What flavor gatorade u want lol?!
Old Dec 3, 2009 | 04:03 PM
  #1083
boss1984's Avatar
ok joe took care of the fuel system for me..hooked up my oil pressure gauge and did some other lil things..i have a date with the dyno again saturday..so i HOPE the wiring fixes the fuel issue..ill keep u updated
Old Dec 3, 2009 | 08:06 PM
  #1084
built54's Avatar
I hope so too, but im sure that wire being 4 times the size of the stocker, it should give it the voltage it needs now.
Old Dec 4, 2009 | 09:27 PM
  #1085
Veteran: Army
today is saturday, but you're a few hours behind
Old Dec 6, 2009 | 01:53 AM
  #1086
boss1984's Avatar
went to the dyno and it is STILL running lean..everytime at 4500rpms it starts to run lean and drop fuel pressure...so im getting a new regulator in a couple days and a fuel pressure gauge so i can see if it drops after that..any ideas would be very appreciated
Old Dec 6, 2009 | 08:07 AM
  #1087
JMC's Avatar
JMC
25 Year Member
Have you given any thought to the fuel pump itself? Could it be faulty?
Old Dec 6, 2009 | 08:51 AM
  #1088
150xlt's Avatar
what does it do when you put the old tune and pulley back on? I would definitely get a fuel pressure gauge and go from their. If pressure is holding then you know it isnt your fuel system and its in the tuning. What does your tuner say about it, does he have any ideas? I hate it when **** like this happens but i guess it is just the nature of the beast. Good luck man
Old Dec 6, 2009 | 09:37 AM
  #1089
ONELOWF's Avatar
I wonder about this too. 400 lph pump should deliver. Won't the stock lines and rails support this much hp??
Old Dec 6, 2009 | 09:58 AM
  #1090
150xlt's Avatar
L guys are making 650ish before needing to upgrade the lines.
Old Dec 6, 2009 | 11:47 AM
  #1091
built54's Avatar
his fuel pressure is dropping every time at 4500 rpm, its not the tune. I suspect a bad pump or a bad regulator.
Old Dec 6, 2009 | 03:35 PM
  #1092
boss1984's Avatar
we even tuned it to under the hp that i made last time and it still ran lean at 4500...every time no matter what it started to lean out at that rpm..he thinks it could be the pump or the regulator as well..im ordering a gauge tommorrow and ill have a regulator here in a couple days as well and go from there...its very very aggravating
Old Dec 6, 2009 | 03:54 PM
  #1093
built54's Avatar
Im gonna bed its the regulator, I hope so atleast. much cheaper fix
Old Dec 6, 2009 | 05:31 PM
  #1094
boss1984's Avatar
Pray with me lol... I put it in second going 45 floored for barely a second saw 20psi and went sideways. It's begging to see 6000rpms!!
Old Dec 6, 2009 | 06:11 PM
  #1095
150xlt's Avatar
Sounds like it is going to be a beast when you get it lined out man. Me you and built need to have a get to gether this spring. What was the wb saying when you saw 20psi?
I hope it is an easy fix. I hate going to get tuned it is always seems like something goes wrong and it makes me nervous as hell watching it on the dyno.
