vacuum leak test
Old May 27, 2008 | 08:05 PM
sharpie248's Avatar
vacuum leak test
Just passing along a tip for checking to see if you have a vacuum leak when troubleshooting an obd code. A mechanic told me to spray starter fluid all around the engine while it is running. If the motor revs up, then there is a vacuum leak. Spray limited areas until you pin point the leak.
