rounded cylinder head bolts
Old May 26, 2008 | 10:54 AM
F150-n-PA's Avatar
I'm in the middle of a job to replace the head gaskets on my 97 Ford F-150 (4.2L, V6) and I rounded the heads on two cylinder head bolts. I'd like your opinion on two approaches I'm considering ; 1) epoxy a ½ drive socket to each bolt or 2) use an EZ-out.
Old May 26, 2008 | 11:07 AM
grizzstang's Avatar
I think the EZ-out has the best chance of success. I am not sure if the epoxy would hold for you but it sounds just crazy enough to work.
Old May 26, 2008 | 11:43 AM
keith97xlt's Avatar
get the sears "bolt out" set best 20$ you can spend. those should spin them right out.
Old May 26, 2008 | 11:57 AM
torkum's Avatar
Have you tried a 12 point socket? If that doesn't work try a standard size socket that equal to the metric.
Old May 26, 2008 | 12:44 PM
bxstang2000's Avatar
I wouldn’t try the epoxy I don’t think it will be able to hold long enough to break the bolt loose. I would use a damaged bolt/nut remover. These will usually be able to break most of the bolts loose. The only thing is once you use them once they really don’t work as well. So I would make sure you find the one that’s tight and hammer it on until it goes to the base of the bolt head. Then use a 1/2" breaker bar and get it loose. Here is a link to the remover im talking about http://www.sears.com/shc/s/p_10153_12605_00952166000P.
Not sure if it’s the same thing as EZ-out but it think its your best bet.
Old May 26, 2008 | 01:19 PM
keith97xlt's Avatar
yea.. thats the bolt out set i was talking about.ive gotten some pretty messed up bolts out with those.
Old May 26, 2008 | 02:22 PM
F150-n-PA's Avatar
RE: rounded cylinder head bolts
Thanks everyone, especially bxstang2000. I located a ½ drive bolt remover for $15; includes the 15mm I'll need; http://www.sears.com/shc/s/p_10153_1...2061000P?mv=rr. I'm going to try this approach.
I'll get back to you later in the week with a report on how it worked.
Kevin
Old May 26, 2008 | 10:52 PM
Bent6's Avatar
25 Year Member
Just get a socket that's a little undersize for what's left of the bolt head, and beat it on with a hammer. You may need a SAE socket if the original bolt was metric. Tire shops use this technique to get stripped or locking lug nuts off wheels, and it works well. If it was a socket head (allen bolt), you can beat a Torx into the hole.
Old May 27, 2008 | 08:44 AM
JMC's Avatar
JMC
25 Year Member
I have a set of those Sears nut/bolt removers. A good investment. They helped me out of a tight spot more than once.
Regards
Jean Marc Chartier
Old May 27, 2008 | 10:26 AM
Buzsaw's Avatar
IMO; I would try a 6-pt socket (tight fit) more bolt surface to grip on. Usually the 12-pts do the rounding.
Old Jul 26, 2009 | 09:17 AM
F150-n-PA's Avatar
Kevin
Finally got the job finished. I was so disgusted with myself for rounding the bolt heads and then for not being able to get past it that I let the job sit until about a month ago. Got a friend to grind the heads off the two bolts. In the process he ground the seat on one hole and damaged the valve cover surface. $150 later I had another friend TIG weld the damaged areas. The adventure continues. While removing the passenger side exhaust manifold I damaged (broke) the EGR tube. $20 later I had yet another friend weld that. The rest was just wrench work. While removing the rocker arms I didn't pay attention to how the fulcrum was oriented; there are angled oil channels on the mating surfaces of both parts. I assembled them with the oil channels aligned. After sleeping on it I figured it the surfaces would have a better chance of seeing oil if the channels crossed. So I fixed that. The moment of truth came last Tuesday. I'm happy to report the engine runs very smoothly. And the feeling of accomplishment...priceless.
Kevin
