Is Royal Purple that much better?
Old May 21, 2008 | 04:20 PM
kaboom10's Avatar
I've seen a dyno run on TV where there was a few extra ponies made on a run. If I'm going for every last pony like for racing I would use it. Otherwise I run Amsoil thru out and have had great luck with it.
Old May 21, 2008 | 10:24 PM
Fifty150's Avatar
Royal Purple is good, but not the best. Of course, how can anything actually be "the best"? I use Royal Purple & Lucas Oil on my cars. Both brands are good. Front & rear differentials, transmissions, transfer cases, and engines.
Old May 22, 2008 | 09:08 AM
phatboyspam's Avatar
yah i've heard good things about lucas as well.
so the general opinon is most any synthetic will do. nothing justifies buying RP over any other brand??
thanks for all the insight guys!
Old May 23, 2008 | 07:14 AM
openclasspro#11's Avatar
Originally Posted by risupercrewman
The only place I've seen RP on consumer markets around here are PeP Boys, & local Speed Shops! It's $7.42 A quart! They can keep it as far as I'm concerned! I recently switched over to MotorCraft Syn-Blend 5W-20, from running the 1st 18,000mi on Mobil-1 5W-20....Mobil1's price was always rising so I ditched buying an oil from the world most greediest company! I am more than satisfied with the Motorcraft Blend, the 5.4 runs just as smooth & is just as quiet with the MotorCraft Blend!...............
you stopped buying from wal mart?
Old May 23, 2008 | 07:20 AM
tech-doc's Avatar
HERE'S YOUR SIGN!!!!
He is not buying oil from MOBILE! Walmart sells MC blend as well!
Old May 23, 2008 | 07:37 AM
B-Man's Avatar
And here's YOUR sign - risupercrewman was inferring that Mobil is the "world most greediest" company.
openclasspro#11 was insinuating that Wal*Mart is... Hence the statement about not shopping there...
I agree with openclasspro#11.
Old May 23, 2008 | 07:47 AM
thanks- you saw my point-greedy isn't the word for walmart-surprised for as much china **** that they sell - that they didn't sell out to them
Old May 23, 2008 | 12:34 PM
risupercrewman's Avatar
I Get the Motorcraft 5W-20 Synthetic Blend from WalMart! $10.36 for a 5-Quart Jug, $2.36 for the quart Bottles, MotorCraft Filter 820S- $3.36! Cheapest oil change I ever done!...............
Old May 23, 2008 | 02:19 PM
I get my MC synthetic blend from the dealer. I get coupons for $24 oil changes.
Old May 23, 2008 | 07:43 PM
I really like the MC synthetic Blend! I notice no difference in the way the 5.4 runs in terms of smoothness & engine noise upon startup in the mornings, since switching from Mobil-1! I just turned 20,000 today! I've seen so many posts here about loud 5.4 3v's with engine noise, maybe I just seen to have a good one built on a Tuesday or Wednesday?..............
Old May 23, 2008 | 08:46 PM
wrobo23's Avatar
Originally Posted by kaboom10
I've seen a dyno run on TV where there was a few extra ponies made on a run. If I'm going for every last pony like for racing I would use it. Otherwise I run <insert brand here>
I agree - unless you are using your truck as a dragster, I honestly doubt that you'll have THAT much to gain from it $ to $. Now, as far as longevity? It's been said that RP is better than most, if not all syns. Is that true? Who knows. I would consider running it everywhere but my oil, which gets changed all the time. I can't see the benefit of using it in a dd.
Old May 24, 2008 | 04:32 AM
Fifty150's Avatar
Any gains, 1-3 MPG @ best, will be from a full fluid exchange. Not just engine oil. That means transmission, transfer case, front differential, rear differential, and engine oil. Some people also use the radiator additives that Red Line & Royal Purple market. I, myself, have used Lucas Oil Upper Cylinder Lubricant in all my vehicles.
