What is this?? How can i fix it?
Old May 19, 2008 | 08:59 PM
Ranger7489's Avatar
My truck only has 70K miles on it, I have an automatic trans, when i really get on it (around 3,500-4,000 RPM's) I hear this really horrible tapping sound just before it shifts into the next gear. It only does it at WOT. Not under normal driving (like 2,000-3,000 RPM shifts)
Anyone have any idea what it is?
This truck has been babyed its entire life, Ive run full syn in it sense the day i got it, and everything ford recommends i do at the correct miles. (flushes, filters, ect..)
Old May 19, 2008 | 09:13 PM
built54's Avatar
is it coming from the engine or transmission
Old May 19, 2008 | 09:15 PM
Ranger7489's Avatar
Engine, sorry. Nothing hitting on the shroud or anything like that, Its internally.
Old May 19, 2008 | 10:21 PM
chiefFX4's Avatar
might be a small exhaust leak. ive got one that only shows up at higher rpm under load.
Old May 19, 2008 | 10:44 PM
Paralyzer's Avatar
sounds like pinging to me. check your plugs and timing. could also be some bad fuel. just an idea....
Old May 19, 2008 | 10:51 PM
halfton's Avatar
do you hear this through the exhaust at all? if so this may possibly be a weak valve spring on either the intake or exhaust port. had this problem on a past 460, low to mid range powerband under load about 2000-3000 rpm. problem arose after a few nights of high revin, wheeling in the snow.
