0315 code?????
Old May 18, 2008 | 12:49 PM
F150canuck's Avatar
Registered User
0315 code?????
I just got a "check engine light". I put the code reader to the test and it came back with a "0315 code". I cant find this code anywhere?
Old May 18, 2008 | 12:52 PM
Year and engine, please.
http://www.gearchatter.com/viewtopic11737.php
Old May 18, 2008 | 02:32 PM
mrainey889's Avatar
From the sticky thread topic at the top of the engine forum...
https://www.f150online.com/forums/sh...d.php?t=312874
The search feature is your friend if you use it...
Old May 18, 2008 | 06:14 PM
F150canuck's Avatar
Registered User
I did use the search feature and found no results. It is a 2003 S'crew 5.4.
Cheers
Old May 19, 2008 | 07:11 PM
FordTech1's Avatar
A P0315 is set when the PCM can't learn the crank trigger wheel profile....MP_LEARN I believe....possible causes could be the trigger wheel itself which is behind the front cover and not so easy to check, a bad connector or a bad crank sensor.....I can get a more detailed description of the problem if needed.....
