Oxygen sensor
Oxygen sensor
I have a 2005 F-250 with the 5.4 in it. I bought O2 sensors Bosch #15664, but they look very different from the originals located before the cats. They look similar to the post-cat sensors. I know looks aren't everything, but I found 3 different part numbers for denso O2 sensors; 234-4045 for pre-cats, and post-cat part numbers 234-4071 and 234-4212.
Has anyone else run into this, or should I even be worried about it?
This is a cut and paste directly from Bosch's website.
at the following link.
http://www.boschautoparts.com/RB.NA....in=5&Make=FORD
I got them in and they seem to be functioning fine so far. I sure don't want to take them back out again, though it was not as hard as I had envisioned.
Thanks for the help.
15664 Oxygen Sensor - OE Type After Catalyst Two required; Check / Replace Interval: 100,000 Miles
Locate Retailer
15664 Oxygen Sensor - OE Type Before Catalyst Two required; Check / Replace Interval: 100,000 Miles
Locate Retailer
Locate Retailer
Locate Retailer
I've even cut them up at one time for other reasons - I seem to remember varying in serial numbers on the casings as well - Like 867's(front) and 869's(rears) were the number differences, but the internals were Identical - same size ceramics (two white wires for heaters) / Signal and direct PCM ground -(Grey and Black wires).
I've flipped them without any issues what so ever.
The difference on the sensor itself, is exactly what Mr JMC posted. The difference in the truck is the program that determines it's duty cycle/responsibility via location - Where it's connected in the harness chain.
