97 f150 4.6 triton no power?
Old May 15, 2008 | 10:39 PM
Camarothatcould's Avatar
Has anybody here used 02 simulators? My buddy uses them on his T/A. . .
Old May 15, 2008 | 11:01 PM
dfishrmn88's Avatar
I agree with a couple of the above threads. Check your cat converters. I was having the same problem and had to have both replaced. Power came back and mpg too. Mine only had 22,000 mi on them and they were bad.
Old May 15, 2008 | 11:21 PM
RedRider150's Avatar
Originally Posted by CRASH594
Red I would have the transmission filter changed. I had that issue on my 97 and it cured the problem.
Ok that sounds good!
Im gonna have my cats checked out too and maybe see if any of these problems could exist b/c of the torque converter.
Old May 16, 2008 | 01:34 AM
Motaman's Avatar
OK to clear some things up.
Cats where checked they said they had the correct pressure or something to that effect. (I am not a mechanic)
All filters have been checked/replaced
I did a minor cleaning of the TB/intake short of removing it and doing a real fine job.
changed the spark plugs and cables.
It seriously feels like the brakes are on all the time but they are not even dragging.
And yes i am stock
Old May 16, 2008 | 03:18 AM
po1911's Avatar
well trust me pro diagnosis will save you a ton of headache I spent two weeks throwing parts at my truck and this is what i found was wrong with it
https://www.f150online.com/galleries...300&anum=16452
that is a 2 inch peice of rubber hose that goes from the fuel pump to the hard lines coming out of the tank so yes throwing parts at it is not a good thing I spent damm near $700 to fix a $0.26 peice of damm rubber
if you are not getting codes (CEL) then make sure the shop tests the fuel system pressure
Old May 17, 2008 | 01:01 AM
Motaman's Avatar
thing is pro that the truck runs fine it just has lost the pick up it used to have i have no hesitation when i accelerate. I just have no power for when i am pulling and the milage is crap. but trust me i am going to try and figure this out the cheapest way first.
Old May 17, 2008 | 01:07 AM
po1911's Avatar
well then you might want to take the entire TB off and give it a good cleaning my 99 with 206000 was horrific there is a very good thread here on cleaning the tb dedicate a few hours and a half case of tb or I used carb cleaner some q-tips rags and go to town the ports from my egr were nearly blocked solid and the elbow was just nasty
you may also want to have your injectors bench tested and cleaned&dressed i got mine done for 45$ I think.... anyway it wasnt bad just pop them off the truck take them down and the test the spray change the filter baskets new o-rings and pop them back on
Old May 17, 2008 | 01:48 AM
Motaman's Avatar
ya i plan on hitting it sat afternoon and because of this thread i at least have something to go off of and i am thankful for that. thanks guys.
