Smoke at start up
Old Apr 28, 2008 | 01:42 AM
chasmanz28's Avatar
Smoke at start up
Have a 06 5.4 f-150, at start up when the truck sits for a day or so, it burns smoke out of the pipe for a couple of seconds. Truck only has 25k on it and still under warrenty. Is there anything i should worry about, or is this normal for the engine. On a side note my driveway has a pretty good incline in certain spots and seems to burn more when its park on the incline instead of on the flat surface. Any ideas would be great thanks
Old Apr 28, 2008 | 02:03 AM
jbrew's Avatar
What color is the smoke ?
Old Apr 28, 2008 | 02:06 AM
chasmanz28's Avatar
Its blue, oil for sure.
Old Apr 28, 2008 | 08:24 AM
built54's Avatar
valve seals, common problem.
Old Apr 28, 2008 | 09:39 AM
chasmanz28's Avatar
Should i get this fixed under warrrenty? Will this problem get worse over time, if this were your truck what would you do. Is Ford going to say aww its nothing to worry about.
Old Apr 28, 2008 | 10:59 AM
Ford will probably not do anything unless it's using more than a quart every 1000 to 1500 miles.
Old Apr 28, 2008 | 02:12 PM
chasmanz28's Avatar
Yeah thats what i thought, just surprized the seals are bad with only 25k.
