fuel leak broken fule line were?
so today i went to go put air in my wheel barrel from the gas station i jump in my truck and try to start it...it cranks and cranks and cranks....no start im like humm werid then i smelled gas i got out and theres a huge puddle under my truck right under the starter... i follow the gas lines from the filter up to the rail and use a mirrior to look behide the TB. and i dont see a leak i had someone in there turn the key forward while i was under it...i can see it pouring right on the passenger side head and down to the starter and then the ground...What fuel line is this? does anyone have a digram of the fuel lines? 97 F-150 4.6L 128,000 miles Thanks guys.
Check the fitting where the passenger side fuel rail meets the flexible hoses. Also look for a leaking fuel injector O ring or the schrader valve. If the hold down bolt is loose or vibrated out it will allow the injectors to leak.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Yep - Mine came completely apart doing about 55mph taking my kid to school one morning
Pumped fuel all over the motor. That damn spring connector rusted inside and broke. Wasted number 8 coil in the process.
I used my boot laces to tie it back together lol - she made to school and I made it back home . Glad I had those COP's caked up with grease - That could of been allot worse.
But yea, check there for sure.
BTW - That does a good job cleaning your motor - so it wasen't all bad.
Pumped fuel all over the motor. That damn spring connector rusted inside and broke. Wasted number 8 coil in the process. I used my boot laces to tie it back together lol - she made to school and I made it back home . Glad I had those COP's caked up with grease - That could of been allot worse.
well i found it its spraying out of injector number 3 on the passenger side. ive loosen the bolts on the rail and tapd the rail with a rubber mallet a few times and then tryed to tighten it back up but no luck. my friend is here so im going to have him push down on the fuel rail while i tighten the bolts for the fuel rail. Can the O-ring on the injector go bad? i have some more but would they break or stop working? thanks again for all your help.
Yea , prolly split an O-ring - I think Auto Zone carries just O-ring sets for your injectors . I've heard of another guy getting a set from them - But the dealer would be best IMO. I believe your suppose to lightly oil those before installation. I have a bunch , if you happen to be out this way. But my daughters not here, she's in Cali for two weeks - so don't get your hopes up lol.
haha darn. i had 8 extra off the police intercptor fuel rail. the O ring was very stretched out. i took all the injectors on that side out and cleaned them up they were dirty inside the engine part and i put some 5W30 on the top of the O-rings and they went right in fine tightend every thing up hook my batt. and turned the key on an off about 5 times to get pressure back and it fired right up. Thanks again for all your help... Jbrew do you live by Michigan state? i seem to find my way out there alot latey. 96 west to exit 110.
