cooling fan size
Old Apr 20, 2008 | 11:18 PM
King James's Avatar
cooling fan size
Does anybody here know the cooling fan size for a 97 4.6?
Old Apr 20, 2008 | 11:23 PM
built54's Avatar
you mean what you need for aftermarket fans or what?
Old Apr 21, 2008 | 04:50 AM
King James's Avatar
I'm looking at one of these if the adapter I ordered fits the water pump.
http://www.flex-a-lite.com/auto/html...s-reverse.html
Old Apr 21, 2008 | 09:43 PM
King James's Avatar
Nobody knows the size of the fan?
Old Apr 21, 2008 | 10:23 PM
phil6608's Avatar
I think the problem is,,,nobody runs that type of fan!
Most go with an electric fan.
But,,,if that's what you really want to go with. For whatever your reasons are.
I have a stock fan in my basement,,,I can go see how big it is.
Phil
Old Apr 21, 2008 | 10:27 PM
rmadison's Avatar
stock is about 16/17. just go with dual 16 electrics that what most do
Old Apr 22, 2008 | 05:05 AM
King James's Avatar
Phil
I'd appreciate it if you could measure it. I wouldn't mind going with electric but the cost is one of the things preventing that.
Old Apr 22, 2008 | 09:30 AM
primerib's Avatar
20" is the stock clutched fan size.
Old Apr 22, 2008 | 10:45 AM
phil6608's Avatar
The one I have,,,off my 03 F-150 , 5.4 is 19 inches.
Phil
Old Apr 22, 2008 | 03:41 PM
lowflyingbird's Avatar
Dont Do One Of Those!!!
You will LOSE POWER!!!! The reason for a fan with a clutch is that you water pump is not always pushing the fan. Yes it will always be spining, But the fan clutch once cool will be sliping more, and use less of your engines HP to push it. It firms up when hot and does not slip to cool the engine better. Installing one of those OLD SCHOOL direct drive fans will make you lose power since it is always robbing power from the motor to drive it.
Your 97 had a metal fan on a clutch. I do recomend that you get a newer fan which would be plastic, lighter and have better blade design to cool better. Other members have offered one to you. I also have one if you need.
Another option would be going electric. More $$$ and time, but it has some benifit.
Lowflyingbird
Old Apr 22, 2008 | 03:47 PM
NYfordguy's Avatar
x2 to lowflying bird, really those fans you are looking at are a waste of money, unless of course you are looking for the ultimate cooling capacity.
