engine misfire - I think
Old May 8, 2008 | 09:35 AM
disbanded's Avatar
Is there any way that someone could post a picture of the 5.4 engine that shows where the cylinders are, or at least where # 2 is?
Old May 8, 2008 | 06:31 PM
Supercrew05478's Avatar
dielectric grease is just for moisture protection right? cause when i changed my plugs my haynes manual didn't say to put any on so i didn't and nothing wrong yet
Old May 9, 2008 | 04:42 PM
jmg-in-alaska's Avatar
Here is a how-to on doing plugs/COPs.
https://www.f150online.com/forums/li...parkplugs.html
If you have any mechanical capabilities - i.e. think you can do the job once you read the attached how-to, and maybe even after you replace one COP - go for the whole set. It sounds like you are might be picking them off one by one for awhile if you don't just do a whole set. Obviously it is expensive to do the whole thing at a mechanic, but if you can do the set by yourself, you'll be way ahead. Good luck.
Old May 9, 2008 | 05:04 PM
grizzstang's Avatar
Do not use Anti-seize on the plugs. Torque to 12 to 16 ft pounds. I went with 14. Good Luck.
Old May 9, 2008 | 05:37 PM
disbanded's Avatar
Well guys, thanks for your help on this. I am very happy to say that I replaced the #2 coil all by myself in about 15 minutes, and everything seems to be back in order - running good.
I have quite a feeling of accomplishment right now, so I sure hope it lasts this time. But if any more go out then I will go ahead and get the entire set from Ebay.
Old May 9, 2008 | 05:40 PM
disbanded's Avatar
Oh, and the biggest help came from another thread on this site that gave me this info
Placement of cylinders
4......8
3......7
2......6
1......5
.Front.
