P0119 - Intermittent Coolant Sensor
Old Apr 15, 2008 | 01:24 PM
Scrib's Avatar
2004, 5.4 3v - check engine light just came one. Autozone says the code is P0119 - Engine Coolant Temperature Circuit Intermittent. Anyone else run into this one? Ideas on possible fix? Did a little reading and it doesn't sound like this motor has a regular coolant temperature sensor, but has something different located inside the intake?
Thanks for any help.
Scrib
Old Apr 16, 2008 | 08:17 AM
Scrib's Avatar
bump
Old Apr 16, 2008 | 08:28 AM
lowflyingbird's Avatar
On a 2V 5.4 motor
I did not get a code, but the part had an intermittent problem. I found this out with a live data OBDII while driving it. Once in every 5 seconds it read -30 for only a split second. It threw my air/fuel off, economy sucked, black exhaust tip, & poor throttle response. For me it was a $15. part. Yes, under the intake too, and a PITA. Just bite the bullit and change it!!!!
Lowflyingbird
Old Apr 16, 2008 | 12:52 PM
Scrib's Avatar
Thanks. Do you know what the name of the actual sensor is? Probably something I'd have to get straight from the dealer I assume.
Scrib
Old Apr 16, 2008 | 07:26 PM
Coolant temp sensor?
Or engine temp sensor? I bought the one I needed in Autozone.
Lowflyingbird
