oils
Old Apr 13, 2008 | 03:53 PM
ademartin1's Avatar
oils
is synthetic really that much better then conventional or is it just more hype. also what is the difference in high mile oils. what do u guys use and recomend.
Old Apr 13, 2008 | 04:12 PM
built54's Avatar
a search works great
https://www.f150online.com/forums/se...archid=1638861
Old Apr 13, 2008 | 04:23 PM
jbrew's Avatar
You provide nothing ? No motor/miles . Don't expect specific info for your application if you don't provide any yourself . Comon , that's a no brainer.
It depends on where your at in miles and how the truck was treated - along w/what oil was used in the past.
If you run a premium oil on an older engine , it will clean it out , but theres a follow-up procedure when doing so.
Fill out your info - don't ignore this when joining , it's a requirement if your seeking good assistance .
