help with misfire
help with misfire
i have been having a lot of cylinder misfire codes. mainly cylinders 1 and 5. i have pulled the plugs and the plugs look fine.
however they are autolite plugs. they are not motorcraft wires either just a silicone 8mm plug wire. they were brand new when i bought the truck 30k miles ago. are the autolite plugs the reason, after some research it seems like they are the reason but the plugs do not look fouled or bad at all. they are not really dark or white or worn, they look normal.
are the autolite plugs the reason for the misfires? or is it the wires too
1998 4.6 romeo,
1998 4.6 romeo,
I played that exact same riddle in my head for a few months with my 98.
Autolites didn't look bad. Everything seemed normal to the naked eye.
Needless to say, after a set of motorcraft plugs and a good set of wires, baddabing baddaboom. No, more miss.
i only got 8,000 miles outta my autolites and had a slight miss with no codes i changed the wires and plugs to motorcraft and been running fine for 10,000 miles and if all else fails read the fan shroud
[IMG]
[/IMG]
[IMG]
[/IMG]
yeah i got motorcraft wires and plugs. wires were 112 for 8 and the plugs were liek 2.00$$ each i think. and i got duralast coil backs for like 40 a pack or something.
I had NGK plugs in for about 1000 miles before they started to miss, switched back to motorcraft, the ones for about 2.30 each, have not had a miss since (only 800 miles on them though). I am using MSD superconductor plug wires (8.5mm) and MSD coil packs.
Marketing reps push these plugs on third party vender's and cross reference the Motorcraft with these. I finally received a refund after 3 years of writing here and there. The check for $62.18 came from Honeywell about 2 months ago. The plugs were $50 and change when I bought them , but Honeywell gave me interest on top of everything else for my trouble
. They also apologized finally and said AGAIN -We produce Motorcraft plugs speced by your vehicles manufacturer for your model and to purchase these in the future.
