any one know cel codes
ASE help needed. new headers today & Plasma Booster. now CEL:
Code P0053 Heater Resistance out of limits
Code P2195 Sensor signal stuck lean - bank 1
can i drive on these codes?
to lean refer A/F?
to lean refer A/F?
Originally Posted by 1904ord
SAE help needed. new headers today & Plasma Booster. now CEL:
Code P2195 Sensor signal stuck lean - bank 1 sensor
to lean refer A/F?
to lean refer A/F?
The long and short of it is passenger side o2 sensor before cat is damaged, failed. Seems like no big deal.
hootdangmac asked - "Did you disconnect the battery when you were installing the mods"
Long and short - If I wanted help , I wouldn't ignore questions asked. Specially good ones like that one.
Originally Posted by Klitch
ive never seen 2195 listed? either way, check out your wiring to that particular sensor to see if anythings obvious. it may be as simple as replacing it.
Tumba/Klitch PO2000 series codes are listed here -
http://www.pacificp.com/index.php?main_page=page_10
Should be added to the sticky, but yea, it's locked and I don't have a frickin key
