4.6l Stroker Kit
Originally Posted by joshmac4.6
Well I take a step back and look at the rear end of every 97-03 I race, the 5.4's don't scare me, but I like to know what I'm up against.
no, sorry if i got you got confused. i got the weak little 4r70w auto in the 98. since it blew i got the built one. they really built it up the guy took out the book and showed me all the stuff they did. it sounded like spanish to me but they went through the whole thing with me today when i went back for the check up. its not bulletproof but its deff stronger. i love the quick firm shifts.
Originally Posted by 600Polaris
no, sorry if i got you got confused. i got the weak little 4r70w auto. since it blew i got the built one
The 4R70W is a pretty stout tranny. I've had mine built to handle 650H.P. The weak point is the crappy stock TQ converter. I ballooned like 4 of them. Switched to a Precision Industries converter and never had a problem again.
yeah i put both trucks on there...the 97 got totalled and a 130 mph head on.
guy had a diebetic siezure, was goin 80...hit me head on i was doin 50. flipped me into a high tension telephone pole. i busted right through the thing broke it into 3 pieces. hit it with the passenger side cab/roof...totalled the rig walked away, well ran the t part of the pole was bobbin above my head with all the wires. he skidded a 1/4 mile up hill with no front end, tires.
wish i could post pics...
The only thing about changing to a 5.4 is you have to buy one. I understand that when you start with more power you end up with more. But if you buy a motor, hopefully with the ALL the right accessories and then build it, that's money that could be dumped on performance for the 4.6. Plus, no aggravation of having to do the swap. In my case, I would have to buy everything to convert my procharger to the 5.4...just more mack to dump in the 4.6... JMO For me...unless I change my mind, I'd probably build my little 4.6.
I'm just a handful of bolts from pulling the block in my 4.6 from this headgasket R&R. Where does the extra stroke come from on these kits? Different heads on the overbore kit? I'm just wishing, but still.
Someone needs to try the Hitech stage 2 cams in their 4.6 F-150. The Mustang guys are getting sick numbers out of them. Would like to see what they do to torque curve.
Anyone know who makes a 4R70 that will take 800 on the input side?
I'll probably switch over to a 4R100 "MONSTER BOX" when I finish my project.
Originally Posted by CDB03STX
The only thing about changing to a 5.4 is you have to buy one. I understand that when you start with more power you end up with more. But if you buy a motor, hopefully with the ALL the right accessories and then build it, that's money that could be dumped on performance for the 4.6. Plus, no aggravation of having to do the swap. In my case, I would have to buy everything to convert my pro charger to the 5.4...just more mack to dump in the 4.6... JMO For me...unless I change my mind, I'd probably build my little 4.6.
