Changing the oil
Changing the oil
Gonna change my oil this weekend. How many quarts does an 05 5.4 take. Checked the book and it doesnt say but dont want to do the work and not have enough to put back in.
The manual says 7 qts of Motorcraft 5W20 synthetic blend. The disclaimer at the bottom of the chart says you don't have to use synthetic blend, regular dino oil is just fine for 5000 miles. Puts the oil level about halfway between add and full.
QUOTE=RUSS04;3146420]7 QTS 5W20 Motorcraft oil 1 Motorcraft oil filter FL820S
[/QUOTE]
BEST REPLY, SHORT AND SWEET
banana:
banana:
Mark- see my posts under "oil capacity question". I also had a '99 w/5.4 and I thought I remembered using 6 qts. when I changed but Chilton says 7 qts. for all the modular 5.4's. Either Chilton is wrong or or or- oh this is all so confusing:o. I don't have the glove box manual (went with the truck) so I can't check that. It looks like the 5.4's have always taken 7 qts. unless Chilton is wrong.
Id bet that the 3-valve motors hold 7 quarts.
It kinda sucks that they changed that, because it was really convenient to just buy a case of oil and 2 oil filters and you were good to go for 2 oilchanges.
No biggie, I guess. Ive never seen Motorcraft oil for sale by the case anyways...
Page 214 of the 1999 F-150/250 owner's guide states that all engines take 6 quarts (5.7 liters) of Motorcraft 5w-30 Super Premium motor oil.
Even still, Ive never seen Motorcraft oil in the case. Ive only seen it in quarts and gallons.
