Dtc Help!!!!!
Old Apr 1, 2008 | 10:49 PM
jmt0645's Avatar
Dtc Help!!!!!
goin down I-10 earlier today the truck out of nowhere lost all of its guts and fell flat on its face basically, pulled off on the side, turned it off then restarted it and pulled 3 codes with the edge, P0606/P1000/P2106. P2106 i know is TAC malfunction-forced limited power. what does this mean is up with the truck? it runs fine now
Old Apr 2, 2008 | 06:30 AM
FordTech1's Avatar
P0606 is the code for the failure mode being entered for the electronic throttle body..basically something between the APPS, ETB and PCM didn't mesh and it went into failsafe mode.
P1000 is the OBD systems readiness not complete....all of the OBDII monitors have not set since the last time the PCM was reflashed...possibly from loading a tune in with your edge recently? The EVAP monitors can take a long time to set so I wouldn't stress too mouch about it.
P2106 you got that one.....
Thing is there is usually another code set along with those that "points" to where the problem may have been like a P2135 or something close to that.
