Strange Overheating!
I have an '01 supercrew 4.6 4x2 w/70.000 miles on motor. Today i towed my boat for service. Ambient about 80deg, speed at 60mph, rad. flush 2yrs ago. No trans cooler, (just orderd one today) A/C runnig, and with a slight grade, The temp. climbed very high almost to red. Shut down A/C, slowed to 50mph. and ran heater, temp. started to drop some, however, not much. Exit fwy. while driving the streets the temp. dropped to almost normal operating range. I thought it was due to the extra load, while on the fwy. When i dropped off the boat and was on the fwy with the A/C running it was doing the samething. So I again exited the fwy. and had lunch, after aprox 90min. I checked under the hood and found the overflow tank was at mid level, and there was pressure when I removed the cap some steam escaped, along with a fishy like smell, I took the streets home and again the temp. was at almost at normal range. I never had any issue's with overheating before while towing. I checked the fan clutch tonight by spinning the fan and I felt some resistence. Any suggestions, Thanks.
Go to Autozone and rent a coolant pressure tester. When testing look for external leaks. If no external leaks check your oil level to make sure its not elevated. This could be the beginning of a headgasket leak.
The thermostat has not been replaced since purchasing the truck.
If it was to be the head gaskets, what I'm I looking at to repair this issue and how difficult of a job is it. I looked at the engine and I did not noticed anything leaking, the motor is clean and dry. When I run the engine it is smooth, I did noticed that the fan clutch is winding up and down, however, the RPM's are at 700 and steady.
OK, I changed out the thermostat and I also replaced the upper rad. hose. I went for a test drive with the A/C on. Drove up some near by hills and back home, all in all a total of 10 miles. I did not noticed any signs of overheating, seems to be normal, however, when i raised the hood to check for leaks I touched the new rad. upper hose and it was hard to compress, I opened the rad. cap and the pressure released. Is this normal to have the upper hose acting this way? And do I have to bleed out any air that may have enterd the system? Thanks for the help.....
