Spark Plug Torque
Old Mar 21, 2008 | 01:49 PM
LLM07's Avatar
Spark Plug Torque
Quick question, I have not been able to find any mention of the proper torque setting for plugs on a 5.4 (2001). I am sure someone must have mentioned it in a thread somewhere, but I havent seen it. In any event, can someone fill me in? Also, there seems to be dispute about the use of anti seize. Am I correct in thinking that 97-03 5.4s dont need any antiseize on the plug threads? Thanks.
Old Mar 22, 2008 | 02:25 AM
JMC's Avatar
JMC
25 Year Member
The torque spec is 9-20 Nm or 78-176 in/lbs. No where does Ford recommend the use of anti seize on the spark plug threads for the 2 Valve engines. I personally use anti seize on the plug threads. I also torque them by feel.
Regards
Jean Marc Chartier
Old Mar 22, 2008 | 12:30 PM
LLM07's Avatar
I appreciate the information, thanks.
Old Apr 10, 2008 | 11:38 PM
fordification's Avatar
sorry, my book also give a wide spread torque number. 78-176 is a large spread. is this right?
also I backed off a couple and check, they seem to be about 40-50.
Old Apr 10, 2008 | 11:43 PM
buzzsaw714's Avatar
meh, I just get them snug in there.. not loose and not TOO tight.
Old Apr 11, 2008 | 01:45 AM
it was more like 25ft-lbs so I tried 15ft-lbs. didn't make it to 15. I think with the plug popping out caused the thread damage. not good.
Old Apr 11, 2008 | 02:25 AM
Paralyzer's Avatar
spec for the 2v is 13ft/lbs
Old Apr 11, 2008 | 02:27 AM
Klitch's Avatar
i go by feel, finger tight, then roughly 1/4 turn. never have had any problems over the course of 4 years and roughly 60k miles.
Old Apr 11, 2008 | 11:02 AM
JMC's Avatar
JMC
25 Year Member
Remember this is inch pounds and that is 12 times less than foot pounds.
Regards
Jean Marc Chartier
Old Apr 11, 2008 | 12:43 PM
Quintin's Avatar
I run them down by hand until they bottom out, and go another 1/8 to 1/4 turn. No anti seize.
Never had a problem.
Old Apr 11, 2008 | 08:40 PM
Regards
Jean Marc Chartier
right. figured that now. thanks.
Old Apr 12, 2008 | 10:22 PM
DrTriton's Avatar
18-22 Nm is the factory spec. for the 2V engine. Do NOT under or over torque them.
Old Apr 12, 2008 | 10:41 PM
Klitch's Avatar
i wanna see u get a tq wrench in there on #4 and read it... lol
Old Apr 12, 2008 | 11:09 PM
jbrew's Avatar
The 03's have two different sets of specs - Depending on the heads used - Reference build date/then VIN for the correct #'s in 03.. My service manual and on the DVD state~12 -16' lbs is spec (97 - 02). BTW - once there over torqued - DON'T back them off - it's to late. If you have , you'll be back in there wrenching on her real soon, bit it will be allot funner 2nd time around
I torque by feel as well - I run all the plugs to flush w/a length of 5/8 air hose per instructions. Then give them a little tweakage 1/4" or so. - Done ! And they stay there
