Best Low end Torque Cam for 96 PI 4.6L
Best Low end Torque Cam for 97 PI 4.6L
OK I have a 1997 F150 4x4 4.6L. Just got a set of 2001 heads, upper/lower intake, yadda yadda yadda. I am going to P&P the heads and intake and all. I want cams to help with pulling. Power down low. Will never be raced so do not care about top end. I have searched and 99% are for guys that want top end.
Usually a cam upgrade requires a programmer and you didn't say if you were going that route. Here is the catalog page for the 4.6 and 5.4 Ford engines from Comp Cams. I have the 102100 in a 4.6 for pulling horse and hay trailers and it put a lot of grunt in the little engine. I do not have any programmer or chip, just the factory specs. I also have the 3.73 T-Lok gears but the 4.10 would be a better choice.
http://www.compcams.com/technical/Ca...6-07/62-63.pdf
