5.4L spark plug change - warm or cold engine
Originally Posted by Irish FX4
Ford recommends room temperature. That could be any temp.
Id go with a cold engine and soak the crap out of the plugs over night.
Id go with a cold engine and soak the crap out of the plugs over night.soak the hell out of it. If you really want it warm, reconnect the COPS and warm it up.
The most recent 3 valve 5.4 Ford tsb states have the engine cold and use Ford carb cleaner to soak.
Originally Posted by benjaminh98
Can I get a link to these TSB's for changing plugs?
http://64.233.167.104/search?q=cache...ient=firefox-a
Originally Posted by JMC
Well I guess we will change that to room temp then. So do we warm it ip a little if the outside temp is -20?
Regards
Jean Marc Charier
Regards
Jean Marc Charier
I've done them cold, hot, or in between, on 2V, 3V and 4V engines. Sometimes I don't have the luxury of waiting for the engine to reach the "proper" temp, so take that for what it's worth. Ford states to remove 3V plugs with the engine at room temp, I feel they come out easier with a little heat in the engine.
Cold. If the engine is warm you run a much greater risk of stripping the threads. The heads are made out of aluminum, so it doesnt take much to strip the threads.
You want the engine to sit overnight, or for at least 8 hours.
Originally Posted by sam1947
I guess it would mean that we pull the engine out, bring it in the house and let it get to room temp...then do the plugs
Originally Posted by clambelly
What's the normal room temp down east by you ? Do I need to bring mine inside to get the temp down [bring it into the AC] because the morning temp is in the low 70's ?
