Lucas oil?
Old Mar 11, 2008 | 07:02 PM
krazyballer's Avatar
Lucas oil stablizer?
Does any one use this on a regular basis? Is it alright on such a old truck im sure it is but im just wondering also how much should i add for 6 quarts of oil.
Old Mar 11, 2008 | 08:09 PM
Fifty150's Avatar
Good stuff. The directions are on the bottle.
Old Mar 12, 2008 | 01:17 AM
masseyman's Avatar
I wouldn't use it in an engine that is in decent condition. Any good motor oil already has all the additives it needs in it. IF the motor oil maker wanted you to use lucas with their oil, they would state something like this on the oil container: for best results use with lucas oil stabilizer. The lucas will only thicken the oil and throw off the additive balance. On the other hand if your engine is pretty well worn out and is using a great amount of oil or has low oil pressure due to worn bearings, lucas oil stabilizer is a good product to add to you oil.
Old Mar 12, 2008 | 07:30 AM
keith97xlt's Avatar
the lucas stabilizer works well.. i use it on my 96 crown vic w/ 140k. it was a cop car before so.. it was already beat. it has slowed oil consumption. your in tewksbury krazyballer?? im over by worcester.
Old Mar 12, 2008 | 07:38 AM
KEITHHATTER's Avatar
The Lucas Oil Stabilizer works great for quietning down a chattery motor.
My truck takes 6 quarts to fill. I use 5 quarts of my regular oil and 1 of the Lucas. I only do this 2x a year. It is very sticky and I do fear gumming u an engine with too much of it. It has dropped my oil consumption as well.
Old Mar 12, 2008 | 10:23 AM
Fifty150's Avatar
Are we on the same page here? Are we talking about the same thing? There is more than one thing that goes into the engine - one way or another.
Lucas Oil manufactures a wide variety of products.
Old Mar 12, 2008 | 10:34 AM
tech-doc's Avatar
Well, the only product mentioned is the one on the first line the OP posted.
*Lucas Oil Stabilizer*
I have used this product for years and love it. Use is periodically in a noisy engine and it will run much quieter. I have also seen it *reduce* blowby in my rig. I haven't had any ill effects yet. *knock on wood*
Old Mar 12, 2008 | 11:45 AM
Labnerd's Avatar
This post certainly shows the power of advertizing. The Lucas Stabilizer is nothing more than a viscosity enhancer. There are no anti-wear, anti-corrosion, friction modifier additives, or anything in the mix to make your engine go one mile farther. If you think you need this in your oil, I'd suggest buying a heavier viscosity oil. That's all you're getting out of this anyway.
Old Mar 12, 2008 | 11:52 AM
That's all the old STP Oil Treatment is - a viscosity enhancer. It pours like syrup.
Old Mar 12, 2008 | 02:46 PM
Yea im in tewksbury boring small little town lol.
