iac restrictor
Old Mar 5, 2008 | 05:43 PM
rmadison's Avatar
iac restrictor
has anyone ever heard of this. came across it today just searching ebay. says it restricts your iac to keep high idle down when shifting. sounds like b/s
http://cgi.ebay.com/ebaymotors/IAC-R...spagenameZWDVW
Old Mar 5, 2008 | 08:22 PM
torkum's Avatar
Got my vote for BS. That will set several codes and cause idle problems, not even sure if a custom tuner can work around that one.
Old Mar 5, 2008 | 08:28 PM
rmadison's Avatar
o i seen b/s too just never seen it before and there were a few on ebay. they also had a egr block too. wtf
Old Mar 5, 2008 | 08:35 PM
torkum's Avatar
The EGR will work only with a custom tune and if you do a search we have had great debate over how effective it is or isn't. I'm staying out of that one.
Old Mar 5, 2008 | 11:16 PM
2006krman's Avatar
These restrictors are primarily used on vehicles with manual transmissions to help with hanging rpm between shifts. I have used one on my 04' MACH1 4.6L/ 4V engine for couple of years. Works as advertised! Only difference the one I used is made of stainless. Purchased from member on mach1registry.com web sight
