Problem Reading OBD "Communication Error"
Old Mar 4, 2008 | 07:37 AM
philm's Avatar
Well my "Service Enginer Soon" came on and I ran down to autozone to have them read the code for me. The scanner get a "Communication Error" everytime it trys to read the code. Any clues.
2000 F150 SuperCrew 4x4
4.6L
Old Mar 4, 2008 | 08:14 AM
FordTech1's Avatar
Could be a pushed back pin on your data link connector or more than likely their connector is worn and not making good contact...maybe try another store before going to far with it.....
Old Mar 4, 2008 | 08:16 AM
projectSHO89's Avatar
Replace the fuse for the cigar lighter. It's on the same circuit as the power feed on the OBDII port that supplies the scan tool.
Old Mar 4, 2008 | 10:11 AM
FordTech1's Avatar
Yeah, don't forget the simple stuff...
I'm used to our scan tool which has an indicator if the power feed is good to the scan tool...I tend to forget that not everyone is using our stuff....
Old Mar 4, 2008 | 12:00 PM
philm's Avatar
Thanks, the lighter is working but I will check the fuse anyway and see if I have any power at the connector with the meter.
Phil
Old Mar 4, 2008 | 01:26 PM
TECHDOC's Avatar
Phil
If the scanner powers up, the fuse is good. Sounds like a scanner software issue to me.
