temp sensor
Old Feb 27, 2008 | 05:55 PM
tbones's Avatar
temp sensor
2000 f150 4.6l the temp sensor is reading low, below the usual normal reading. Woundering what the problem might be. Possible theromstat bad? 73,000miles on truck
Old Feb 27, 2008 | 05:58 PM
joshmac4.6's Avatar
Does the heat still work properly and have you noticed a loss of power or fuel economy?
Old Feb 27, 2008 | 06:01 PM
tbones's Avatar
temp sensor
heat works properly. no loss of power.
Old Feb 27, 2008 | 06:24 PM
joshmac4.6's Avatar
Well it's prob. just the temp sensor, it uses two ECT's, one for the PCM and one for the idiot gauge, if everything is ok, then the one for the gauge is prob. just bad.
Old Feb 27, 2008 | 06:31 PM
NYfordguy's Avatar
Check the connections on the sensors, remove and reconnect ensuring you hear the click of the lock engaging.
Old Feb 28, 2008 | 12:53 AM
JMC's Avatar
JMC
25 Year Member
2000 4.6 has only a CHT (CYLINDER HEAD TEMPERATURE) sensor. No coolant sensor. The CHT sends a signal to the PCM and the PCM sends a signal to the instrument cluster. Does the engine get up to operating temperature? Is the rad warm, hot or cold? The CHT is located on the driver side cylinder head in the valley at the front. Not an easy sensor to get to.
Regards
Jean Marc Chartier
Old Feb 28, 2008 | 01:04 AM
joshmac4.6's Avatar
Regards
Jean Marc Chartier
Well thats funny, the Ford Service Manual on PTS I'm looking at definetly shows a ECT, and a CHT, and the ECT goes to the I/C.
Old Feb 28, 2008 | 01:27 AM
tbones's Avatar
temp sensor
I'll look into it more on the weekend and let you know the outcome.
Old Mar 1, 2008 | 05:59 PM
tbones's Avatar
temp sensor update
I replaced the thermostat. and the temp gage is back to normal.
Old Mar 1, 2008 | 06:32 PM
jbrew's Avatar
Just pull it out and clean the bottom of it - they'll develop a film or coating over time on the bottom. Clean. - Prolly only take you 15 minutes to do and it should be more accurate - Well, as accurate as they can be anyway
Old Mar 1, 2008 | 07:28 PM
FordTech1's Avatar
2000 model year still used a CHT and an ECT, the ECT is located near the t-stat on the crossover I believe. 2001 and later went to the CHT only setup......
Old Mar 1, 2008 | 07:35 PM
JMC's Avatar
JMC
25 Year Member
My 2000 MY, 1999 build, did not have any CTS. I used the harness from my 4.6 to run this 5.4 and there was no CTS........
Regards
Jean Marc Chartier
Old Mar 1, 2008 | 07:40 PM
jbrew's Avatar
You may be right, but the funny thing about that year (2000) is that some 4.6L's had COP ignitions and some had coil packs.. I'm not totally sure, but I'm thinking the ECT was deleted on the COP upgraded models - mid year.
Old Mar 1, 2008 | 07:42 PM
JMC's Avatar
JMC
25 Year Member
My 00 was built in 99 and it had COP ignition.
Regards
Jean Marc Chartier
Old Mar 1, 2008 | 07:43 PM
FordTech1's Avatar
Dude not doubting you...maybe the build date comes to play..I just looked up in the PC/ED's for 1999-2004 and the last year it listed one was 2000...My PC/ED is the one hooked up to Ford's servers so I'd be willing to bet it is pretty accurate............... cheers!
