How to get the max of low end torque for towing????
Old Feb 24, 2008 | 03:55 PM
20Screw01's Avatar
Ok so I have a 01 4x4 screw with a 4 inch lift and I want to use it to tow a 20ft enclosed car trailer. I am looking to get the max low end torque for towing that I can for now as a NA 5.4. Then maybe do a eaton swap next year. What would you guys recomend to get max towing power out of a 5.4l ? long tubes,throtle body,programmer?? It has a cai,airaid spacer some exhaust and 3.55s. Idea's? Thanks!
Old Feb 24, 2008 | 04:01 PM
joshmac4.6's Avatar
Long tubes will give you good torque, swap the 3.55's for a set of 4.10's if you are wanting good bottom end, a set of under drive pulleys and a tuner would be good as well.
Old Feb 24, 2008 | 04:58 PM
MOford21's Avatar
I'd get some lower gears first and then go from there
Old Feb 24, 2008 | 05:07 PM
electricfrank's Avatar
4.10's and troyer tunes
Old Feb 24, 2008 | 05:42 PM
20Screw01's Avatar
Ok so here is what im thinking .... 373 gears (due to I commute and dont want bad mpg) hypertech programmer , pacesetter lth's, magnaflow muffler,pullies,cai,airaid thottle body spacer and a fresh set of plugs and cop's. What should this bring the hp and tq to?? Also what is stock?
Old Feb 24, 2008 | 05:54 PM
jbrew's Avatar
You have a 5.4L - 4.10's all the way .. 3.73's wouldn't impress you for the expense. I'll bet you'll get better mileage with 4.10's than you do now.
Check out the "OtherPowertrain" Forum on this site for more info. It's expensive to have done on the 4x4 , but you'll get the best results changing up the gearing from 3.55's.
If your running rubber over 305's (33's), you may want to go with the next size up from 4.10's.
Like I said - Check out the other forum for more info..
Old Feb 24, 2008 | 08:02 PM
Veteran: Army
also get 24# injectors, they will add up to 100ft lbs at part throttle, perfect for towing, I only took mine out because they are too small for my supercharger
Old Feb 24, 2008 | 08:04 PM
joshmac4.6's Avatar
Really now, was that with or without a Throttle Body Spacer?
Old Feb 24, 2008 | 08:08 PM
built54's Avatar
Uh.... no
Old Feb 24, 2008 | 08:20 PM
Fifty150's Avatar
Troyer is one of your best options. If you give them a call & discuss with them what you want to do with your truck, they could put together a package for you with everything that you will need from intake, to exhaust, to pulleys, to tuning, et cetera.
Old Feb 25, 2008 | 02:33 PM
Jordan not Mike's Avatar
What size tires are you running?
Old Feb 25, 2008 | 03:40 PM
malexander52's Avatar
100lbs...........NOT
Originally Posted by built54
Uh.... no
x2
Old Feb 25, 2008 | 03:44 PM
Veteran: Army
Uh.... no
*nevermind, you guys are starting to act like faster150* sorry I even tried to help this guy out*
Old Feb 25, 2008 | 03:45 PM
Veteran: Army
Old Feb 25, 2008 | 03:46 PM
Veteran: Army
Originally Posted by malexander52
x2
*never mind*
