Troubleshooting P0174
Old Feb 23, 2008 | 12:00 PM
matt5849's Avatar
Hi, I was wondering if anyone could offer me any help in figuring out what the problem actually is. I have an 04 5.4 supercrew with 39,000 miles and the truck runs fine right now. I have already cleaned the MAF (check engine light stayed off for almost 2 weeks) and the light has come back on(cleaned it again and the light came back on the next day), is it possible that it is bad or is it something else? Any help would be appreciated, thanks!
Old Feb 23, 2008 | 01:56 PM
The book says if it isn't the MAF, it's a vacuum leak or a clogged fuel filter/low fuel pressure.
Old Feb 23, 2008 | 02:02 PM
jbrew's Avatar
Or , the drivers side upper intake gasket.
Old Feb 23, 2008 | 03:13 PM
Makes sense to me - that sure would cause a vacuum leak.
Old Feb 23, 2008 | 05:39 PM
joshmac4.6's Avatar
Possible causes, from Ford PC/ED manual
Fuel System.
Fuel pressure regulator (leaking, faulty).
Fuel filter plugged, dirty.
Fuel pump (weak, check valve leaking).
Leaking/contaminated fuel injectors.
Low fuel pressure or running out of fuel.
EVAP canister purge valve leaking (when the canister is clean).
Fuel supply line restricted.
Fuel rail pressure sensor (incorrect reading).
Ethanol content in the fuel
Air Induction System.
Air leaks after the MAF.
Vacuum leaks.
PCV system (leak or valve stuck open)
Improperly seated engine oil dipstick.
Air induction turbulence due to incorrect air filter.
Exhaust System.
Exhaust leaks before or near the HO2Ss (exhaust manifold gasket, mating gaskets)
EGR system.
Vacuum hose disconnected on EGR System Module (ESM) applications
EGR valve tube/gasket leak
EVR solenoid vacuum leak
Secondary Air Injection.
Damaged/malfunctioning secondary air injection system (mechanically stuck valve).
Air Measurement System.
MAF sensor (contaminated, damaged, or faulty)
Old Feb 23, 2008 | 07:43 PM
jbrew's Avatar
Why is the MAF listed - Is Ford contradicting itself? Scorpio says the same thing.
It can only be the MAF if BOTH banks test positive for lean.
Old Feb 23, 2008 | 08:00 PM
joshmac4.6's Avatar
The section of the PC/ED covered all these DTC's P0171, P0174, P1130, P1131, P1150, P1151, P2195 OR P2197. It is possible that a MAF can cause just a problem with one bank, but other problems must also exist. MAF is one of the last components to check in this pinpoint test.
Old Feb 23, 2008 | 08:22 PM
jbrew's Avatar
My PC/ED is just giving me Oasis #'s. Are you connected to Oasis ? Or you just going from a DVD or something?
Old Feb 23, 2008 | 08:26 PM
joshmac4.6's Avatar
On PTS, under service publications, and then to PC/ED
Old Feb 23, 2008 | 08:44 PM
JohnHL's Avatar
I have an 03 with a 5.4 and about 42K. I haven't had the P0174 problem.
However...............I do have a 2000 Windstar and the 3.8 is notorious for the P0171 & P0174 problem. The fix is to change the Isolator Bolts inside the plenum. After a while the seal on the stock bolts breaksdown and causes air leaks. I changed mine out and it wasn't too much of a hassle. I don't know if the 5.4 has something similar but I figured I'd pass the idea along. Below is the Windstar link talking about it.
John
http://www.automotiveforums.com/vbul...d.php?t=338113
Old Feb 23, 2008 | 08:47 PM
jbrew's Avatar
I found it here -
-PCED OBDII-A ~ Diagnostic Subroutines-
Old Feb 24, 2008 | 04:26 PM
matt5849's Avatar
Well, I replaced the fuel filter today so hopefully that'll do it. I'll keep you guys posted to see if that does the trick, thanks for the suggestions.
Old Feb 24, 2008 | 05:41 PM
jbrew's Avatar
That's a good place to start. Since your replacing the filter, it's a good time to check your fuel pressure @ the rail along with your regulator. I think a cheap guage is about $30 - Auto Zone will rent yuh one cheaper than that.
Old Feb 24, 2008 | 11:24 PM
matt5849's Avatar
Just out of curiosity, does anyone know why after I cleaned the MAF the first time the check engine light stayed off for two weeks; and when it came on again I cleaned it again and it came on the next day?
Old Feb 28, 2008 | 02:01 PM
matt5849's Avatar
Well, the check engine light came back on again this morning. I've noticed that every time it comes on it seems to be below 10 degrees; would that have anything to do with what is going on? Also, I went to autozone again to see if the same code came up and it did. Any help would be welcomed, thanks!
