Aftermarket Temp Gauge Sender Location ???
2000 5.4L F150
I bought a aftermarket electric temp gauge.
The instructions that came with the gauge says to replace the current sender with the new supplied sender. I don't think I want to do that.
I'm conflicted as to where to put the new sender. Another thread mentioned the thermostat housing (is it threaded or must I drill and tap it?) On the drivers side of the block, just in front of the bell housing there is a freeze plug. Just above this freeze plug is a half inch threaded plug.
Would either of these locations work , one better than the other, or is there another , better location ?
i was also wondering about this because i am thinkin about gettin one of those gauge pods that go up that side pillar and i was wondering where i would have to put the sender without messin with the one that is already there.
I couldn't reach my threaded block plug so i put in 5/8" brass hose barbs and tee in my heater core supply hose, cut and hose clamped, done deal, no leaks and I just had to ground and wire the sensor up, perfect readings and easy to service/change, remove, etc.
arent there some random holes in the heads/ on top of the engine for things like this?? ive seen alot of emtpy threaded holes on mine...i also am gonna get a Temp gauge...with my luck if i cut the hose itd leak.
Yes, there is a freeze plug on the bottom drivers side that is easy to access. It should work, take a socket extension and remove it but you'll lose radiator fluid. I am pretty sure it is the same size as the sensor.
Originally Posted by PlainJane150
2000 5.4L F150
X2!!
I actually had no choice but to do mine this way as I have a mechanical gauge, but exact same theory. The temp probe on a mechanical gauge wont fit into any existing port. I would have done it this way either way.
