PCV elbow 5.4
Originally Posted by Dans4x4F150
can someone tell me where this is???
https://www.f150online.com/forums/sh...d.php?t=320993
My '99 doesn't have a "PCV Elbow" on the back of the intake... It has a long plastic tube that makes a gentle arc behind the intake and then comes straight at the manifold. No elbow, just a normal straight hose connecting it to the plenum. I'll see if I can get a picture. It may be worth finding if you can eliminate the elbow and never have to worry about it again.
hmmm mine is a 99
fixed mine!! Well my PCV elbow was the problem it was in bad shape. It came off in 2 pieces. Went to parts store 10$ later truck is running like a new truck But man it was hard to get my hand to the back of the intake manifold!!!
This site RULES !!!!
Originally Posted by jbrew
Yea , good find! BUT, you can order just the elbow, like Steve said..
Thanks again !!!!!!!!
The PCV valve on the 4.2L is a liittle further back in the valve cover passenger side. Just follow that line and it will lead you right to it
I show two types - One w/2 90 degree bends and the other is vertical w/the 90 degree bend being on the boot to pipe connect.
Doesn't list a heated one , but I've seen them before where there fastened by a metal retaining clip - goofy looking deals.
So glad I found this forum.. I chased this code for months and finally pinned it to the PVC elbow. A 8$ part almost broke my bank. Glad I came here. Saved me a ton of time. I'm still not sure how I missed that elbow when I did the starter fluid test for leaks. But all is well (just waiting in this stupid DMV line now)
