whats wrong?!
Old Feb 14, 2008 | 09:32 AM
Titanium's Avatar
whats wrong?!
i got a 1990 f-150 with a 300 inline 6 in it. yesterday i noticed that if i would let it sit at idle for a min or so it would just die by itself. I also noticed yesterday that it was missing out every now and then and sometimes i couldnt even go past 2k rpms and if you did the tach would bounce and when you would let off the gas a big back fire would come after. So do you guys got any ideas what it could be? i was thinkin that it might not hold the idle due to a bad fuel pump not sure though.
Old Feb 14, 2008 | 09:52 AM
shifty_85's Avatar
yeah im going to lean towards fuel...when it dies doe sit sound like its starving? check/chage fuel filter then test the fuel pump....also check the intake filter make sure theres nothing clogging it up.
Old Feb 14, 2008 | 11:39 AM
tech-doc's Avatar
Sounds like fuel to me as well.
Old Feb 14, 2008 | 02:08 PM
If that engine has a mechanical distributor in it, this can be indicative of bad distributor shaft bearings/bushings. Had this happen to me on an old BMW.
Old Feb 14, 2008 | 07:01 PM
Titanium's Avatar
i figured it out. my fuel filter was clogged solid. now the truck runs better than it has in the past year or so.
Old Feb 14, 2008 | 07:10 PM
shifty_85's Avatar
haha that will happen never heard of it all the way soild.. i replaced mine not to long ago. at least it was something cheap How are those strait 6's? lots of power? ive always been a fan of the 4.9L
Old Feb 14, 2008 | 10:09 PM
I've seen them plug solid.
The 4.9 has low end torque up the wazoo, but horsepower and acceleration is not in its vocabulary. It's a true truck engine meant for pulling.
Old Feb 14, 2008 | 11:02 PM
malexander52's Avatar
Great motor
We had an 82 with a 300 I6 and a single barrel carb. It would pull like a mother but it wasn't quick by any means. It did get awesome gas mileage though. I think Dad would get about 22 in ti running 65 and 70 here in texas. Idled smooth as glass. I6 is where it's at.
Old Feb 15, 2008 | 07:31 AM
shifty_85's Avatar
power stroke needs to make a Inline 6...powerstrokes always get pwned by cummings because there inline 6's...witch are TQ monsters. if the 300 has a ton of TQ shouldnt it get rolling pretty fast because when you WOT that feeling that throws you in your seat is TQ isnt it? i donno ive always loved inline 6's and powerstroke needs to make a 4.9L Inline 6 stroker!!! or better yet a 7.3L inline 8 stroke HAAHAH...*ive seen an inline 8 somewere* but that would be like 800Ft lbs of torque thatd be alsome
