Thottle Delay Fix?
Old Feb 11, 2008 | 08:22 AM
Mo Power's Avatar
Everyone,
I did clean the MAF with electrical contact cleaner. It helped somewhat, but it does not cure it. What about cleaning the injectors? What do you guys use for that?
Old Feb 11, 2008 | 09:59 AM
shifty_85's Avatar
i think i read some were that there is slack in the throttle cable and when you hit WOT it doesnt open up the throttle plate all the way...i thought i saw that on here some were for the F-150's 97-03 not sure thoe..i saw it in the *free HP* thread that was started a while again....donno if its true...
Old Feb 11, 2008 | 01:06 PM
jbrew's Avatar
Originally Posted by Mo Power
Everyone,
Clean it again - specially if you oil the air filter. Clean the throttle body and plenum. You could pull a little slack out the cable using 1 zip tie on the cable in the cab by the fuel peddle (just one!) but I don't think that's the problem.
Personally I don't believe cleaning the injectors is ever needed. My last set along with friends at work have all purchased new injectors on ebay . The most I paid for a new set is $65 . It cost more to clean them.
Old Feb 11, 2008 | 01:36 PM
RightTurn's Avatar
sounds familiar, we had the same problems on the 99-04 Mustangs. there was a problem with not being able to reach WOT becuase of the pedal positioning.
Old Feb 11, 2008 | 01:59 PM
jbrew's Avatar
Yea, but that wouldn't cause this guys problem.
For some reason the TPS position isn't right on the meter in these trucks and needs to be adjusted. I didn't notice any difference choking up the cable. But I did notice a difference after making the TPS adjustable and re-positioning correctly.
BUT - If I had to guess at what the OP's problem is with hesitation - I would go with the regulator or dirty TB and Plenum. A dirty TB can cause throttle plate hang up. In-turn, possibly confusing the whole system to a certain degree. - Enough to cause the problem.
Old Feb 11, 2008 | 05:35 PM
Mo Power's Avatar
Thanks for all of your help! When it warms up, I'll clean the throttle body and see what it does. Sure wish I had a heated garage!
Old Feb 11, 2008 | 07:57 PM
Buzzz's Avatar
Is there a way to fix the throttle delay on the older generation F150s? My '02 with a 5.4L has a noticeable delay and I need some ideas on how to fix it. Here's some things already tried:
1. New fuel filter
2. New COPs
3. New Plugs
4. Cold Air Intake (Ebay)
The only thing not done was cleaning the throttle body. Will this make a huge difference?
Any other ideas?
Thanks!
It's called a clunker!
